Hull stringer material
Status
Not open for further replies.
Scott06
Here are a couple of pictures of the engine bay of a 2004 Sea Ray 225 Weekender . . . The structural areas (stringer, battery tray, etc) look to have laid-up fiberglass based on the texture . . .
So it would be fair to say it is not a molded fiberglass stringer grid (which would be quite smooth in appearance).
As for salt vs. fresh water. Wood cored boats tend to rot quicker in Fresh water vs. salt. Corrosion on the metal parts are a bigger issue when running in salt. Either is manageable with the corresponding maintenance.
That weekender is much different in terms of construction than my ‘04 200 sport. Not the best photo of stringers as I was just getting done repose rings , but the stringers and floor are smooth and shiny just like the hull. I think this model and hull design was released in 04.
Bobberboat
2004 and thereabouts was a turning point for the boat building industry. The manufacturers who used wood and desired to stay with wood went to KDAT types of plywood . . . product names like 'Perma Panel' and 'Greenwood XL' may appear in their promotion materials. Their products are pressure treated plywood and Kiln Dried After Treatment (ie. KDAT) making them suitable for use in fiberglass boat construction. They exhibit rot resistance as regular PT lumber does.
Other manufacturers began using foam coring instead of wood for their stringers and structural components, and others began using molded fiberglass stringer 'grids'.
Many boat manufacturers are fairly vague about the details in how their boats are built . . . otherwise you would not buy them 🤪
Many boat owners do not have a good understanding of how their boat was built :unsure:.
I have found that factory tour pictures and videos are a decent source of information as to how a boat was built. Additionally, you can look well into a boat's structure to get an idea. You can also find some boat review articles that mention construction methods or materials.
You can also find boat restoration threads (here on iBoats) that reveal the guts of a boat. We know for example that @Friscoboater 's 1995 Sea Ray had lots of wood in it. As to if/when that changed, some research is probably needed.
The challenge would be to find out what was used in 2004 . . . vs in the 1990's vs. what is used today. :unsure:
I have a 84 success that the floor and stringers are rotted. With the cost of wood and the nasty job of fiberglass I got to thinking. Pallets, pallets! I want to stay away from wood. So plastic is what I came up with. Looking for advice here.
If I was to use the plastic pallets/crates to build the floor which would be like a grate system? Then lay trex a composite decking material for the floor. Epoxy the grate system. Nothing would be completely sealed like a wood floor with fiberglass. Rather air circulation to allow the system to dry. Thoughts? Hope I have posted this in the right place as I am new here. Thanks
jbcurt00
If I was to use the plastic pallets/crates....
No is the answer, but you'd be better served to ask in a topic of your own instead of hijacking an old inactive topic.
Answer will still be no, but you can ask it anyway in a new topic
Status
