Howdy all,
Broke a pin in my Eagle 320 and have not had much luck finding a back case for it. Will pick up a plug from Fry's and do a fix on it.
I have been considering upgrading to a Sounder/GPS and was wondering if anyone has used either the Hummingbird Matrix 97 or the 787c2i with the quadrabeam transducer which gives a wider viewing area? Both are color which I believe is almost a must in an open boat in bright sunlight! The 320 was really almost invisible at times in my Tracker Super Guide 14.
They both are dual frequency and come standard with the dual transducer which can be upgraded to the quadbeam!
I am trying to get into the Lake Washington Cuthroat fishery and the Kokanee in some of the local lakes? Also sounds like the quadbeam would be good for when our Sockeye fisheries are open on Lake Washington.
Any advice or reference to other sounders that might meet the requirements for above type fisheries would be appreciated!
Catching some high lake trout and hope to get to the Kokes in August, but believe I need a wider beam sonar?
