Tig
- Sep 20, 2009
- 416
I'll apologize up front for this being long winded but I spent a year thinking this through, setting up the boat and testing. I hope I got it right. If I missed something, please let me know and I will get the information you need.
I have had my own motor boat since I was eight and I have owned this particular boat for one year. Last season was a very short one for me due to work, so I'm still feeling it out. When I first got this boat, a stainless prop was at the top of my shopping list. I pretty much knew exactly what I was going to buy. Then I started reading the Iboats prop forums and the Hwsii white papers. Over time I came to realize that the prop I wanted is not the prop I need.
The boat came with an aluminum elephant ear prop I believe it's a 13" pitch but it has no markings. I ran it for a week or so then I swapped in the spare. The spare was a 11 1/4 x 13, 3 aluminum prop I believe it's what's called a semi cleaver. I tested both for the heck of it. Too bad about the one being unmarked.
Last year the anti-vent plate was 7/8" below the keel and I ran 33.7 mph on the GPS with two adults on board at 6300 RPM. (tail wind) This spring I raised the motor up two holes all the way to the top. The anti-vent plate is now 5/8" above the keel.
The boat will porpoise very easily if both occupants are at the helm. Loaded this way she does not like much trim, only two touches up with the semi cleaver, one touch with the elephant ear. Next tap and she starts to porpoise. That being said, it's an open boat with room for 4 in the bow. Last year on one occasion I had a capacity load (over 850lbs) with over 500 lbs of it in the bow. It did not plane until I trimmed the motor up two taps, which I found odd. Once on plane the boat trimmed out beautifully and ran as if it was meant to carry that load, in that way.
It's windy here and white caps are part of a nice day on the water. Under normal load when the waves get to two feet the ride suffers with a light bow.
Getting good numbers is quite an interesting process as I found out.
First WOT test after raising the motor. Average load, two adults. 32.8 mph @ 6500 rpm. ~14% slip I was trimmed up and it must have been ventilating a bit. I had never seen it run 6500 rpm before. I don't consider this a "good" number since it is not reproducible.
I also tried a solo run against the wind in a light chop @ barely 6000 rpm I hit 33.9 mph. ~6% slip, but this is not a typical load.
Now the real numbers;
1. Boat:
1995, Boston Whaler Dauntless 15, 9 degree deadrise at the transom,
Max rated hp 70 on the plate (60 in the original manufacturer brochure that I found in online archives)
15'1" L, 6'4" wide, 850 lbs base weight
3. Normal use and load:
Cruise and fish, normally two people, both sitting at the helm when under way. 6 gallons of fuel. Total running weight estimate ~1550 lbs
This boat does see stretches of Lake Ontario where agility is valuable for a smaller vessel. Day trips require crossing a 5 mile stretch where 4' seas are common in the afternoon.
Occasional ski/wakeboard and max capacity cruise in sheltered waters.
Local elevation is about 250'
4. Engine:
Honda, BF50A, 1995, 50hp, Gear ratio 2.08, RPM range 5500 to 6000 RPM, weight 208 LBS
6. Anti-ventilation Plate height above keel of boat.
5/8" above keel. Recently raised engine to the bottom hole on the engine bracket. This is as high as she will go.
Click to enlarge pic.
7&8. Props and performance specs with typical load of ~1500 lbs:
Aluminum prop, unknown manufacturer.
11 1/4 x 13 semi cleaver
RPM GPS mph
4000 17
4500 22.1
5000 24.6
5500 27.8
6000 31
WOT ~6050 31 mph
Prop has pits but no dings. It appears to have been repaired at one time.
No trim tabs, whale tails or other goo gahs on the hull.
Second prop.
Elephant ear prop with absolutely no markings other than an R. I include this data for the purpose of illustrating the different loads that it was tested under.
Passenger in bow. I Was able to trim to 90 degrees before it ventilated.
RPM GPS mph
4000 12
4500 18.5
5000 22.8
5500 26.1
6000 29.2
wot ~6050 29.6 mph
Passenger with me at the helm.
RPM GPS mph
4000 15.3
4500 20.6
5000 23.4
5500 26.8
6000 29.2
wot~6100 30.2
Observations: Tolerated less trim than the semi cleaver, one touch only.
Hole shot did not feel as good, (impression)
Here is a pic of the anti vent plate at WOT with a typical load, which is two people sitting at the helm.
Based on that pic it may seem that the motor could go up one more hole, but there isn't another hole.
Here is a pic of the trim angle of the motor while running with two at the helm. Note the angle of the anti-vent plate to the keel.
Below is a pic of the anti-vent plate at WOT if a passenger rides in the bow. I guess a small open boat with moderate power is all about weight distribution.
9. To prepare the engine I decarb'd it with seafoam. Seemed to be pretty clean.
Checked and adjusted the idle air mixture. It ran best set to manufacturer spec.
Sync'd the the carbs.
Oil is fresh. Plugs are clean and gaped to spec. Compression was tested last year.
10. Performance issue I am trying to correct;
This boat spends most of it's life around 25 mph with two people sitting at the helm. Currently I have 18% slip at that speed.
Top end is good, mileage is good, hole shot is OK. At capacity it's not much of a hole "shot", but we plane.
I would like to go to an SS prop in search of marginal performance gains. If I could choose where any gain went it would be to hole shot. I can't afford to loose performance there.
Thank you very much for taking the time to recommend a prop for me.
1. Boat:
4. Engine:
RPM GPS mph
4000 17
4500 22.1
5000 24.6
5500 27.8
6000 31
WOT ~6050 31 mph
Second prop.
RPM GPS mph
4000 12
4500 18.5
5000 22.8
5500 26.1
6000 29.2
wot ~6050 29.6 mph
RPM GPS mph
4000 15.3
4500 20.6
5000 23.4
5500 26.8
6000 29.2
wot~6100 30.2
