NatedoggAZ
- Mar 7, 2018
- 182
Hey all -
Need some help with a diagnosis here - I am totally lost on what the heck is going on here...
So - I replaced my hydraulic manifold the other day - but didn't get a chance to add in the fluid and test it out.
Just yesterday - I went over to where it is stored and brought a few quarts of hydraulic fluid. I filled up the reservoir on the pump and cycled the outdrive up and down a few times. The pressure built up and the OD now stays up - previously it was tied up because there was no hydraulic pressure due to me removing the pump for overhaul...
Anyways - after I cycled the outdrive up and down a few times - I noticed that the fluid was still a little cloudy - so I may have to drain it again...
....but that is the least of my worries now...
After I though all was good and well - I noticed fluid coming out of the drain plug hole - as well as fluid coming from between the transom and the housing!!
I probably have at least a busted hydraulic line - but fluid coming out from the gimbal housing???
What exactly is going on here??
Thanks in advance for your help/support/comments:
