I have a 2008 Smoker Craft 182 Promag which I understand has an inherent porpoising problem. I do not have room for smart tabs or any other tabs because of my kicker motor. I bought the Stingray SR3 because it was a no drill mount and I could see if that type of aid would fix my issues without holes. Basically my boat, other than having a poor design, is tail heavy with a Mercury 150 optimax, a Mercury Pro Kicker (90 pounds) a 22 gallon live well in the back (160 or so pounds) and a 280 pound fishing buddy. The Sting Ray SR3 solved all the issues with only a 2 mph loss at top end. Comes up on plane much faster with much less bow rise, planes at lower speed, no porpoising and is a lot more stable in rough water. The SR3 was mounted after changing props from a 14X19 3 blade to a 14X18 4 blade. The prop change did make a difference but did not solve the problem.
Note: If you follow the instillation instructions on the SR3 it will probably fall off. I made other hardware for installing it.
My question is that is there any performance difference with the different shapes of these tails where the SR3 is curved and others are flat. When this one breaks I would like to put a stainless steel "tail" on permanently.
