Re: Hydrofoil
It wasn't a slam to you, it's that these threads follow the same pattern every time, someone asks if foils work, this is followed by a dozen replies saying they bolted one on thinking they do the same thing as tabs and headed for the water, it didn't work, so in all applications foils are useless and always create problems.
The truth is they are very setup specific and they "may" work well in some situations, but in a totally different way than tabs. On an I/O its not possible to do many adjustments to improve the performance after you install a foil, so if its being used in the wrong way and for the wrong reasons and doesn't give the desired results, why is it the fault of the product.
Now if the outdrive is mounted high and the prop ventilates during hard acceleration, then yes a foil may help by preventing some ventilation. If what you want to do is get on plan sooner, be able to adjust the ride, improve handling and possibly increase MPG, then a foil is not the correct tool on an I/O.
Every application is different, whether it did or didn't work on your boat will have little bearing on whether it will work on his boat (although the chances of one working on any I/O are less than one working on an OB). This is because the hull, HP, type of drive, prop, boat weight, how the owner wants to use it, etc, all come into play.
