Re: Hydrolic Posts/Rams on an O/B
OBJ.<br />Thought I would run this idea past you - for your opinion.<br /><br />John (the worker) has just had another check of the rams etc.<br /><br />1. The resoviours for the Rams is full.<br />2. John described the scatches as pitting, quite severe, and probably been there for some time.<br />3. The seals have not/are not leaking.<br />4. John has sanded the pitted areas down with wet and dry.<br />5. John has suggested he fill and sand the pits with Selleys Aqua Knead-it, (Polymer Repair System)<br />6. John suggests I just drive it, and he keep an eye on it week to week. His thinking is - it is not causing any problems, and if it does when I am on the water, then I release some screw and mannually raise the motor for loading on trailer, then he repair it when home.<br /><br />What are your thoughts on this matter.<br /><br />As a side issue:<br /><br />1. Each of the small Rams are Aud$368 ea<br />2. The Long Ram is Aud$806<br />3. The seals kit is Aud$94<br />So over US$1,200 plus labour, but John does work for me.<br /><br />but.....<br />a 2nd hand one from the wreckers is Aud$990 (US$740) complete (in good condition).<br /><br />The boat was moored in salt water for 5yrs.<br /><br />Thanks OBJ<br />Cheers<br />Phillip
