Hydrolocking Mercruiser 4.3L
My 1996 Mercruiser 4.3L vortech Keeps Hydrolocking if it has been sitting for more than two weeks. i keep it on a trailer not in the water. need help any sugestions will be great
nola mike
Re: Hydrolocking Mercruiser 4.3L
as in water in your cylinders? check your manis/risers/gaskets.
yes water in the cylinders and the exhaust manifolds are the one piece kind
Ayuh,.... There's your Problem, Right there,... Their Leakin'....
I was thinking the exhaust manifolds might be leaking into the cylinders while it was sitting for periods of time so i tried draining them before letting it sit but it would still hydrolock after sitting for a couple weeks or so im wondering if might be something else or if maybe there is still some water left in them after draining.
Bt Doctur
They need to be replaced, not drained
when i bought the boat last year from a dealer he told me that the manifolds had been replaced because the old ones had cracked so im thinking they are good
alien4fish
hhhmmmmmmmmmmmmmm................................... interesting:cool:
nola mike
open cooling system? unless you have a crack in your block, where else could it be coming from?
sgm26
I had a water leak a couple years ago and a hydro lock. When i tried starting the engine, it snapped the starter bolt. Had to remove the engine to replace it. Did a complete overall, and thought the water leak was corrected. Today I just snapped another starter bolt. but there was no sign of water leak yet
However it did have a grinding sound when I started it but then would start and run fine but half way through the day, the starter just started spinning and I had to be towed home.
Any ideas what else might cause this starter problem?
nola mike
Re: Hydrolocking Mercruiser 4.3Lx
This would be better served by starting a new thread...
