I can't find anything for this Sea King!
I know what it is and that it was made by Gale,
sea king 35 twin electric
model gg8837a
serial 06x793914
But I cant find parts anywhere, or a manual, parts manual. I specifically need a fuel pump, or a pump kit, and a carb kit...
Please HELP!
steelespike
Re: I can't find anything for this Sea King!
Well your in luck Your motor is a 61 built by the Gale devision of omc.According to my info the 8837A is a 40 hp. based on the 40D14B Gale.
It very closely resembles the similar Evinrude/Johnson motors of that time.
You may find a Gale service manual right here under OMC manuals.
An aftermarket service manual for all brands of motors 30hp and above will serve you well for basic repair/tuning.
Gale is usually listed in E/J section.E/J info is pretty much identical the only difference being those E/J with the pressure fuel tank.Most routine parts are listed right here at iboats under E/J.
F_R
model gg8837a
serial 06x793914
Please HELP!
This one should work. If the present pump is not mounted to the top cover, switch top/bottom covers.
http://www.iboats.com/Fuel-Pump-for...6518470--**********.329618843--view_id.174140
