I didn't want to restore this 1997 Islander this summer
Fj40fiji
Could happen to anyone!
I was a passenger in an Eliminator Daytona with about 1,200hp once. It had a brand new 572 with AFR heads and twin whipper super chargers; at about 110 mph it siphons beer right out of the can of you hold it level.
Gibbles
Also, picked this up after using my friend’s in his shop. Super convenient.
If you have a need to spray solvent or cleaners, the sureshot sprayer is handy.
I used it to spray acetone to prep for painting and cleaning of an engine block.
Amazon url,
https://a.co/d/1kkhV0C
It does require some method to add compressed air, and it can handle more psi than most single stage home units can dish out.
That was a selling point for me, i wanted to be able to add an unsafe pressure to mine if I so desired.
Default spray pattern is pretty fine.
Adding 150psi to it and it just made toxic clouds of acetone... lol
Easy to mod, and spare parts are easy.
So i modified mine to get more of a "wash" pattern like a can of brake clean.
If i could get gallon jugs of brake clean it would see more use around my garage.
Fj40fiji
That’s an 18x9 “trim tab”, the tape in the middle is the anode location, but I can easily relocate it, and then my transducer. The plywood scrap it’s clipped to is 10” long. Everything I read says keep it 8” or more off set from the drive. I can also relocate or just space the trailer tab out board a little, in fact it might just take a whack with a hammer. The tab could also just be set in another half inch.
Bennett recommends this size tab for a 22’ boat but I see people mostly running 12” wide tabs. Is this too crowded?
Fj40fiji
That’s going to put the actuator close to the support for the swim step too. Probably only 1/2-3/4 inch clearance.
redneck joe
I'd have to do some digging here but one my 26 ft glass Carver with a 7.5 beam i went 12" Bennett.
Fj40fiji
Also, when I put trim tabs on, I can use 316 machine screws, fender washers, lock washers, and nylock nuts. My transom is already .10” plus .090” laminated. I have some 1/8” x 1-1/4” aluminum flat stock, probably 6061, and it’d only take an extra half hour to make backing plates. I could get some angle if I really needed it.
Should I back these up or good enough to just through bolt them?
Fj40fiji
Port side. I don’t have my kicker on right now. The bracket stands off a foot in the up position I think. I’ll have to get it back on and mocked up before I order but pretty sure with the 9” chord they will get along. The 12” width wouldn’t really change it.
redneck joe
I just screwed and 5200
Fj40fiji
Mocking up front bilge pump, routing hose and locating discharge. It is tough to get the hose on and off. Hopefully I’ll be able to get the cartridge for this pump if I need one in the future, it won’t be easy to change the whole pump over.
Fj40fiji
I keep reading to put a 1’ tall loop above the fitting, but matched the 9” of the factory location.
redneck joe
One inch is minimum. It's about physics. If you can make the loop very u shaped not just shaped.
Fj40fiji
I’ll shape it more when I make it permanent. This is really stiff hose, heavier than I should’ve gotten. I don’t think I can bend shorter than 4-5” radius. I’ll put some zip ties around it when I install it fully.
clock the discharge fitting to about 2 oclock vs the 12 you have it at.
Fj40fiji
Why 2 o’clock rather than 12? Is that to resist the hose and get the radius tighter? My thinking is to make the loop as vertical as I can. There is plywood under the gunwhale I can screw a clamp to and support it so I don’t have a lot of stress on the fitting and I figured I’d strap the legs of the U with zip ties to hold the radius tighter and keep the stress off other things. The fitting isn’t sealed or tightened yet, I can clock it differently.
Fj40fiji
That piece of angle running vertically is the mounting point for the starboard cuddy cabin bulkhead. There’s an interior panel that’ll hide the hose. It’ll have to come up through the floor and a shelf, so locating the notches will help me get it routed how I want. I’ll add a pic of the outside when I get home.
its a bilge pump discharge fitting. doesnt really matter much on that, however the hose bends easier with the fitting clocked
