Hi, I bought a 1993 Sea Ray 170 Bowrider over this winter and I did some things such as bellows, tune up including cap and rotor, plugs, wires and a new 140 T-Stat. This has the 3.0 Mercruiser. The previous owner bought a new aluminum 3 blade prop, it’s a 17P. So taking it out, it is hitting about 35mph fluctuating between 4900-5300 rpm. Depends on the day I guess. One day it’s 5300 the next it’s 4900. So I decided on a 14.5 x 19P aluminum 3 blade. Same mercury blackmax prop (I believe that’s what it is) and the RPMs are now 4500-4600 like it should be... but still goes the same speed. The compression is 140-150psi. The carb seems to be in healthy condition too. What are your guys’ thoughts?
