Watermann
- Jan 12, 2013
- 13,834
No way I would temp fate using a torch, that thin AL would warp and be a mess. Then if it even worked and the wad of stuff stuck it would be a huge pain to sand down nicely.
I suggest my favorite hole plugging method using JB Water Weld 2 part epoxy stick. Clean out the hole, sand/scuff up the underside, wipe clean with a solvent and then make a wad of JBWW about the size of a nickel. The reason for the size of the JB wad is so that it doesn't start to kick before you get it in place. Pinch off a piece of JB from the wad and push it in the hole from the underside making a mushroom and with the other hand press down on the JB leaving a bit of a bulge in the hole to sand down flush. This has proven to me to be a very tough and permanent hole repair.
