Silver Eagle
Master Chief Petty Officer
- Mar 16, 2010
- 852
Re: I guess I'm going to bite the bullet...
I bought an 89 Arriva back in 95. It was a 21 ft bow rider. I sold it last year .It had an 230 hp Merc. I/O Chevy V-8. it was a great boat. I paid $9,000 for it and sold it 14 years later for $4,000.The biggest problem was the rubber bellows. They would leak after a couple of years So when ever they started to leak I'd have them replaced and I'd get the water pump done at the same time. The Chesapecke bay is hard on water pumps. One time I had to have my lower unit replaced. I had an Alfa One out drive.They cost around $2,000 to replace. I had hit a log at high speed and it tore up all the drive gears. Thank god for boat insurance. They paid all but $100.00 What Would I do?I'd keep the boat. First I'd put the plug back in the boat.Lower the out drive to operating level. Fill the boat with water to the floor level. See if any water comes out and mark it with a magic marker. If it comes out at the transom you know it the bellows. Than take the out drive off of the boat. Check it for worn gears or maybe it's dry inside. Look at the gears, see if they are bent. If your not sure take them to your local marina and have them check them out for you. While your at it change your water pump. Then if nothing seems to be bad put everything back together. Some times it's that litle thing that is causing all your problems. How's the fuel, Is it old. A good engine tune up cost around $250.00 have the spark plug wires ever been replaced?
