- Oct 25, 2011
- 25,152
Re: i have 1966 starcraft help plzzzz
Try & take a breath when typing ^^^ man this is hard to read esp when reading & referencing pix that have to be 'opened'
Try to use picture IMG codes from photobucket, that way your boat pix look like this:
And makes it much easier to help
It looks like the transom is only 3/4"-1" thick. Leaving too much room between the motors outside bracket & the turn buckles that you tighten from the inside. The transom 'should' be 1.75"-2" thick, that helps carry the load as the motor throttles up & etc, and reduces stress on the fiberglass skin on the exterior of the transom. Measure the depth of the bracket & make sure the motor mount will still fit over the transom after you add a 2nd pc of 3/4" ply.
As you change the amount of overall weight in the hull, people, gear, coolers, fuel or whatever you will need to adjust the trim pin on the motor mount bracket to either raise or lower the bow & get onto plane to run correctly. Does that <<<-- make sense?
With a given weight, as people move around, esp towards the fair forward or rearward (fishing/trolling) when you go to start the motor & make a run somewhere else, you might want to increase or decrease the angle of the motor. But not very often is vertical in the water relative to the hull/transom.
It would help you a great deal to spend some time reading thru some of the forums. Using the wrong terms for parts of boat & motor makes it difficult to help....
Glad it's running & etc, and you've gotten to use it on several occasions.
Good luck & look HERE for a vintage handling of outboards PDF file that may help
should i run some carriage bolts through the bottom plate of transom on motor...and the way the pin is set in the pic..is that right or do i run it all the down on the other in inside the plate..and what could i do to sturdy the boats transom..doesnt seem to be rotted..just seems like i should reinforce..would transom aluiminukm plate work to help sturdy..the way the pin is set in the pic...is not the way i ran it.. i ran it with the pin its sitting on now down..and motor locked into the pin inside...seemed like it was in too much of angle...the motor should be straight right...i was looking at everyonre elses boat yesterday while we were out..and theres were straight..mine was in angle..so plzzz help me out ..first boat ive owned dont want to screw it up ..any advice on any of my questions ...will be greatly accepted...
