Yeah, I was thinking about those clear bags for that same reason! LOL! :lol:Holy Smokes that is one awesome foam job! Great forward thinking! ...and good thing that you used clear bags...in the event that ATF or boarder control seizes your boat :lol:
As someone who as experienced first hand the aftermath of someone trying to adhere something to the hull skin, I recommend not attempting to glue something sub deck. You are dealing with non-absorbant materials...that factory foam is open cell. As agua stated above, it will trap water. Fasten the deck properly and you won't have to worry about watching your hard work float away as you sink :lol:
Got it.the problem with trying to glue anything to aluminum is that it adheres poorly, allows moisture to seep under it possibly forming mini electrochemical cells since the water cannot escape...you may end up with worm holes. (ask me how I know :facepalmThats all we are trying to say...not so much a galvanic potential thing.
Got it.
Hmmm... when I cut the foam wedges I made sure that there was clearance from the top of the foam to the underside of the deck. I've read on here where guys had foam in contact with the underside of their decks and had squeaking noises as a result. I was trying to avoid that situation. If I don't glue the blocks down, they'll be bouncing around under the deck. At least in some places.
What to do, what to do? :noidea:![]()
This is the stuff I used, purchased from my local big box HD store.I was browsing through your post and am looking to see what kind of foam you're using? It looks like a polystyrene, but wanted to be sure. Thanks!
Got it.
I'm jealous, I'm going to replace the crappy foam job from the previous owner and follow your process. Not sure if I'm concerned enough to go for the HDPE bags but in any case, I definitely like the look of how this is coming along. Thanks for sharing.Flotation foam under deck is almost done! Just have to measure, cut, shape, stack, glue and tape the wedges for the most forward part of the bow.
Nice work.
Question for you: is 550# of flotation enough to /not/ let the boat sink if swamped? I know you subtract the 'weight' of the assembly in air but with the motor and such won't that 16 still have negative buoyancy in the water? Not beating you up but wondering if I am missing something.
FWIW I have a friend who sunk a smaller boat with about 12 cubic feet of foam a couple years back; a wake swamped him and then the boat just settled into the depths and was not recovered. Then I remember the Dave Mull experience in a brand new manufacturer's test boat that you'd think wouldn't sink, but a tall follower swamped that one miles from anything on I think Lake Michigan. It too wound up on the bottom but was recovered.
Since I have two boats I am renewing right now, as a result of those two stories this question was on my mind as I watch your build.
My wife really liked this part! :lol:...Not too mention the shrieking of the admiral telling you to slow down and lets go back.![]()
Thanks! Been loads of work but I think well worth it in the long run.Your doing a fantastic job on the foam..
Yeahh... the HDPE to protect the foam from gasoline is based on an experience I had about 20 years ago. It was my fault for being distracted while fueling but I ended up with a deck covered in about 1/2 inch of gas. But totally worth it!I'm jealous, I'm going to replace the crappy foam job from the previous owner and follow your process. Not sure if I'm concerned enough to go for the HDPE bags but in any case, I definitely like the look of how this is coming along. Thanks for sharing.
But I ain't done yet! :laugh:Nice work.
