I need a Propeller for my 1991 Welcraft 186 4.3 L Mercruiser alpha 1 boat?
Status
Not open for further replies.
starwriter
Banned
From what I found so far,I have a 3 blade,14 inch dia.,19 pitch propeller.
Does all the Mercruiser's have the same hub & spline?I damaged my fin tips on my propeller.I haven't removed my propeller yet to know how many teeth spline it is.Reason why I haven't removed it yet is because,as of now I don't have a replacement propeller.The propeller still works but,has some large chips tookin out of it.Thinking right now it still works.It will get me by until I order a new propeller.In other words,I'm affraid to remove it.Then something goes wrong to where I can't put it back on then boatless so to speak.
I was told This is a 15 teeth spline.Is this true?
I was told by another member on this site.I need to know the RPM's & WOT.Why do I need to know that?I mean,I know I need a 19 pitch.I don't want to change the pitch.
I'm simply trying to find another 14",19"P 15 teeth spline & Hub Propeller?
Can anyone cross reference my propeller information to a replacement propeller?
My propeller information is,
14 inches in dia.Or 7 inches from center spline to top of fin.19 pitch.(48.78120A40L19P),(549 E1).Can anyone here cross reference my propeller to a replacement Propeller?I found this information below.But,I don't know if this is correct or not?
Diameter: 14"
Pitch: 19"
Rotation: Right-Hand
Material: Aluminum
# of Blades: 3
Product Details
Mfr. Michigan Propeller
Part No. 95897
Mfr No. 031025
Unit: Each
List Price $132.75
Can anyone give me a hand finding my propeller?
achris
More fish than mountain goat
Re: I need a Propeller for my 1991 Welcraft 186 4.3 L Mercruiser alpha 1 boat?
Go to any Merc dealer with this number -> 48-78120A40 and he will give you EXACTLY the same prop... All Mercs use the same shaft/hub... or go to an aftermarket prop maker with the same number and he'll give you a prop to fit...
Chris....
Diameter: 14"
Pitch: 19"
Material: Aluminum
# of Blades: 3
Product Details
Part No. 95897
Mfr No. 031025
Unit: Each
List Price $132.75
Ayuh,.... 'n yer car will still go to town, on Flat Tires too....:facepalm: :rolleyes:
Runnin' a well BEAT prop is a sure fire way to take out the seals in the outdrive...
starwriter
Banned
From what you said,all mercriuser take the same hub/shaft spline.That basically answer's my questions thanks.As for finding a Mercruiser dealer in my area.That isn't gonna happen.That's why I'm here asking online.If there was a dealer in my area I sure wouldn't be here talking about this.
Just amazing all you experts with boats knows nothing about props.You would think someone here would have a prop book for cross reference.
All I'm hearing is go to a dealer.Well,if there was a dealer in my area.I wouldn't be here.Normally when someone says take to dealer is because,they don't know.
I get one guy telling me to find my RPM's & WOT.I know the pitch I need.19 is my pitch.I don't want to change my pitch.If so?understanable,Yes I need to know that information.
Thanks for all the help!
Best.
achris
Best.
I take exception to that statement!!!
I'll have you know that I wrote a computer program specifically for prop calculations, and that when I bought my own boat shop in the early 90s I also took every different style prop Merc made and put it on my own boat to see how they all performed, so I could accurately inform my clients!
You posted a number that was on the prop... I told you the correct number to get a new prop... I'm sorry if my crystal ball doesn't tell me that you live in such a backward place that you can't even get to a town with a dealer in it!
You have your number, try an on-line dealer, or phone one of the aftermarket manufacturers of prop, give them the Merc number and THEY will give you the cross reference number, or even go to their websites and download their brochure, which have the right props for you....
You are going to have to do some of the work here!!!....
:mad: :mad:
jonny rotten
If you go to a dealer expect to pay twice as much as online.I have a 1991 4.3 alpha 1 with a 14.25 x 21 and have dead on WOT 4400-4800 RPM
achris
OK.. Let me ask you some questions...
You've given us all the details on your current propeller. What exactly are you after? Are you looking for a replacement Mercury propeller? Are you looking for an equivalent aftermarket propeller? If so, which brand?
I've done a quick search (took me under a minute) here on iBoats... This is the results page.... http://boatpropellers.iboats.com/Me...9.00&chart=77&engine_id=765&*******=267610916
Or are you being so lazy you like me to come over, with a new prop, and remove your current prop and put the new one on for you? And I'll do a complimentary tune up while I'm at it!!
Chris......
QC
Wow Stardude . . . Uh, that's a sure fire way to get no help whatsoever. As far as a plan. Click the link that Chris gave you. Good luck.
starwriter
Banned
Well,I'm not here to debate Chris.If you say you wrote a computer program specifically for prop calculations.Then with that so called computer program you should be able to cross reference as well if that's the case.Know one gave me a cross reference number for the number I gave.
It's bassically simple after learning on my own to find a replacement prop.Why,someone here didn't tell this in the first place is beyound me?
You need to know your spline count.
Dia of the Prop.
Pitch of the prop
Last you need to know the brand of you sterndrive.
You only need to know your RPM's & WOT if you are after to change your pitch of your prop.I asked for help cross referencing my prop .Not change the pitch.Then,asking me what brand of prop I'm looking for?Brand doesn't matter.Any brand with a 15 teeth spline ,14 dia,19 pitch will work.I asked for the replacement.That's Michagan brand.Not Quicksilver.
Maclin
I think you are entitled to a full refund of what you paid for the service.
QC
Grrrrrrrr . . . from your gibberish we can't tell if you "know" anything. Sorry. We won't let it happen again. Have a good season :rolleyes:
BTW, next time get a jet drive. That will solve this for you.
paultjohnson
:facepalm: Jeez...
bcbit01
Wow....Everyone needs to chill. Starwriter, even though some epeple are on here to show off how much more they know than others, most just want to help you and you can't bite the hands that feed you. About your prop, you're right. If you liked the performance before the prop got mangled, then figure out what outdrive you have, # of splines, prop diameter and pitch and get another one just like it. Although people tend to have their favorites and different props do have different advantages, brand doesn't really matter much for what you're looking for. Since you're going to all this trouble and expense, I think it would be worthwhile to step up to a steel prop but that's just my opinion. Good luck buddy.
starwriter
Banned
Well,it's pointless to reply but,what the hey......
For starters,I just simply asked."Where can I find a prop for this boat I discribed.".I stated the dia of the prop & the 19 pitch I need.
Basically,I get a person asking me to get my RPM's & WOT.You only need to know that information if your looking into changing your prop pitch.I never once stated I was wanting to change my pitch.I thank chris for giving me that information.But,I'm not after to change pitch.Chris ,stated that all Mercruiser's have the same spline.If that's correct?That's all I need to know.I know my Dia.,I know my Pitch I need.Now I know I need a 15 teeth spline.Put,the 3 together and you have a prop.If I was gonna answer my own question?I would first ask that person "What size & teeth count is your spline?"Mearsure the prop dia.,& note what pitch your prop is?.After all of that, send that person in the right direction."As Michagan,Quicksilver or other.I never was debating anything.I asked a simple question.I will apologize to Chris if I stated anything the wrong way.That's the thing about typing from talking in person.Causes,misleads.
I got to say tho-?Chris answered the question.I see know one else gave it a try.Other then go to your dealer,or ask your dealer.My hat's off to Chris!And thank you as well.I ment no point taking.So,Yes,Everyone needs to chill.Question has been answered.
Best,to all.Kindness kills people.
QC
star,
I still don't know what you wanted? :confused: You gave us the model, part number, manufacturer, even the price. And then asked how do I replace that. Seems like you already did all of the work. Like I said, I still don't get it.
FWIW, we are not rude as a general rule. We try and help even when someone doesn't ask a question. Chris is a very strong Merc tech with a ton of experience, professional and personal. When you start slinging stuff at people that know what they are doing I think you should expect a strong reaction. Sorry. Don't know what else to say.
achris
You know, with all you've written I still don't understand what you actually want to know...
Because it does calculations, not cross-references! :facepalm:
Because you didn't ask the question properly. You ask where to get a replacement for your Merc prop... You were told. It's not our fault if you can't get to a Merc dealer. And that's something else you're never told us about initially, or I would have pointed you at an on-line source.
NO, YOU DON'T... THEY ARE ALL THE SAME FOR MERCRUISER DRIVES! If you buy a Merc prop it WILL be the right one.
starwriter said:
Dia of the Prop.
Pitch of the prop
Again, you don't need to know any of that if you have the Merc number or the propeller information, both of which you have.
At last, you got something right. :)
Brand doesn't matter??? Are you kidding!?!?! You're asking for a cross-reference and you can't tell us which brand you want cross-referencing to! Let me give you an example of just how stupid that statement is....
Let's say you have Champion spark plugs, RV15YC4 for example, and you'd like to replace them... You need to know what brand you want to replace them with before you can get a number.... I could say yes, replace them with 5613438, and without knowing what brand that is you don't have a hope in hell of finding it...
Here's how you should have asked your question....
I need to replace my current propeller, 19" Merc 48-78120A40, as it's a bit damaged. I can't get to a Merc dealer, so Could anyone give me the part number for a Michigan or Solas propeller?
Job done, no arguments... We know immediately what you have, what you want... Would that have been so hard, instead of the waffle and dribble you started with? Any relevant information in that first post was lost.
Enough said, and I'd like to suggest that this thread be closed....
QC
Let's just let it die guys. Thanks all for your participation :)
JB
I am really impressed with the guys who tried to help in spite of hostile replies.
From Rule #1: Disagreements on any topic must be conducted in a polite manner using courteous language.
Having violated the politeness requirement several times, this thread is closed.
Status
