i need help bad
cashman
i have a 1965 johnson rdsl 27 outboard motor it will run fine when up out of the water but when i put the motor down it will run sluggish and die any idea what it can be
Daviet
Re: i need help bad
Do not run the engine out of the water or you will have a lot more problems, no water no cooling.
Sounds like you might have a carb problem, the float level changes when the engine is tilted.
Maybe time to over haul the carb.
Mntom
Re: i need help bad
First check your spark plugs, then look at cleaning and rebuilding the carb.
jonesg
Re: i need help bad
Theres no load on it when out of the water.
If its not firing on all cylinders you will get this problem.
Read the faq files on performing a spark test, don't try doing it with a sparkplug, you need a $12 spark tester set to 3/8th inch gap.
Link to FAQ is in my signature below.
