I need mercruiser 260 serial number
red85k100rs
I have a 1981 Sea Ray SRV225 that I purchased last year. It had a mercruiser 260 in it, but had no mercruiser serial number anywhere; it did have brass freeze plugs!
When I need to order parts I need a serial #. Anyone have any suggestions
I had water & oil issue and said to myself I know nothing about this motor, probably not a boat motor. I decided not to put any more $ in an unknown motor. So I got a short block, honed and re-ringed, new bearings, new timing chain, new brass freeze plugs, and new marine cam.
Here is what I have now:
Crank Shaft:
3932442
1969-85 350 cast 2.45 2.10 3.48 replacement
Motor:
Block #: 3970014
1970-1976 Chevy 350
Front Block Stamps
16R509192 and T0602CMJ
Date? E12 76 (5/12/76)
Intake: 346250
Heads: 333882
74-80...350/400......76cc chambers
Distributor
Mallory YLU624AV
Cap 2090
Re: I need mercruiser 260 serial number
Crank Shaft:
3932442
Motor:
Block #: 3970014
1970-1976 Chevy 350
Front Block Stamps
Intake: 346250
Heads: 333882
Distributor
Mallory YLU624AV
Cap 2090
Ayuh,... So what's the Question,....
You've got very little left of the original motor, so the original serial number's abit obsolete,...
alldodge
Your original engine would probably have been a 260 GM 350 V-8 1978-1982 serial nummber between 4908850 to 6218461. Depending on what your wanting to build and end up with I suggest going to Mercruiser Schematic Part Diagrams and determine which one you want to build.
red85k100rs
Mercruiser Schematic Part Diagrams. That is just the info I needed, Thanks so much
The motor is all built, installed in the boat, and run for about 1/2 hour on a garden hose. Interior gets put back in today, in the water tomorrow.... I hope.
