I NEED THE WIRING DIAGRAM FOR A 15HP 4 STROKE JOHNSON
new2obrepair
MODEL IS #J15FREDR.<br /><br />It is a borrowed motor, won't kick at all.<br />no spark...NO SPARK at all. must be a switch, but the wires are in molded plugs. I do not take those apart on other peoples equipment. PLEASE help if you can? I am an electrician by trade, so I know how to check it if I have the diagram.
JB
Re: I NEED THE WIRING DIAGRAM FOR A 15HP 4 STROKE JOHNSON
That's a '96 engine, Bruce.<br /><br />It would be illegal to copy copyrighted material for you, but you can legally copy it at a library.<br /><br />Good luck. :)
new2obrepair
thank you, I'll try to find one there. Last manual I got from library was not the correct year span or horsepower.
DHPMARINE
The terminals come out of the conectors with the correct tools.The first thing I would do with this engie would be to replace the igition module/power pack.<br />DHP
JRJ
Is the clip in place on the emergency shutdown?
