Re: 22ft. Sylvan offshore from 3.0liter OMC to Suzuk iDF140
Thanks again, you know I should say that this Suzuki DF140 is the extra long shaft. Yes its a 25 inch leg which allowed to set the bracket that much higher. As you can see by the pics its about 6 inches out of the water had it been shorter when taking off the lip under the platform would have actually been dragging in the water. Once on plane that would have been alright but at low speeds it would be a water churner. The other benefit to the higher bracket and longer leg on the engine is that it allows engine to be tilted completely out of the water. This is what I wanted when it spends a few days here and there moored at the bay. It won't be soaking in the salt water
WZ
WZ
