Re: I plan to wet sand and clearcoat my fiberglass boat and need some advice
Thanx again man for the advice. I have to buff and polish the side I sanded and one side down. The other side I started on earlier and realize thers a spot about three foot long and two feet tall that it looks lile someone painted and cleared over .Im guessing that was to hide the faded gelcoat. now I see why so many people suggested against it. It wont sand off easy . Is ther any kind of paint or clearcoat remover I can apply that wont tear up the gelcoat?
Be very carefull about applying any kind of Removers when you think you might have Paint on there.
If someone did a Paint over Gel patch..you might be removing something you should not be. Dont assume that It was done to hide Faded Gel..could have been a repair.
There is a boat build called Sunseeker that has Unbelievable Fade in there blue gel..you can sand and buff it every year and it will fade badly every year.. We end up having to Paint with Awlgrip or Imron and blend clearing it into the gel.. thats the Only fix..
But..you may just have some kinda Magic cure-all crap on there that keeps fading out.
You might just have to get to bare gel and buff it out.
As already suggested sanding with 600 then 1200 then buffing might do you well..
Be aware that you may or may not have repairs that have been Painted..pay attention when sanding.
BTW .. I use 3m Imperial compound. .. no two or three step stuff..just Imperial.. Just me though
Good luck and happy boating
YD.
