I too require subjective advice on mounting a kicker to my boat.
MajBach
Re: I too require subjective advice on mounting a kicker to my boat.
For your setup, a retractable bracket will be hard to use. You might fall overboard trying to get it up and down. If the mount is positioned correctly, you can merely tilt the motor up and it'll be out of the way. I've run many boats with kickers and that's preferable if it fits. Since you need to go custom, just design it to fit.
Tiller is OK, but For the size of your boat, IMHO you need a 9.9 at minimum. That'll use a remote tank. Any model with an integral tank will be too small.
Yet more good advice to consider.
After my last post regarding leaning toward Minn Kota engine mount electrics, I did some more homework and am now reconsidering. I have two batteries on board, both big and deep cycle (series 27?) but I didn't consider recharging options until someone on a different thread here said hooking the two in series prohibits them from being recharged via the alternator on board. I'll need to mull that over as Im not sure I completely agree. I have room for a third battery too if necessary - one I could isolate from the pair and dedicate to engine and ancillary.
Further, I'd like to read someone who has had this set up on a heavy boat. I think 165 lbs would be decent thrust on a boat like mine; say equivalent to 6hp. I'll also need to crunch the numbers more to see how quickly they will drain the batteries as I know if I were to mount a pair onto the leg, I would use them for more than just emergencies.
So, needless to say Im faced with a head scratcher. And now that someone here with far more boating experience than me agrees I am a rare case where aux propulsion is wise, I'm dead set on getting it.
Ironically, shortly after posting the above replies, I walk into my local hardware store and come across this:
http://i1145.photobucket.com/albums/o516/MajBach/photo_zps4f34494b.jpg
Not an identical comparison to be sure but closest match ive come across to my situation. His was a 20' boat and likely a 1000 lbs lighter but he had reservations about electric motors as well. His set up suits his purpose (trolling) perfectly. The mount was quite sturdy and he said it came with a SS backing plate for underneath but wasn't cheap. He also reminded me that we both have power steering to tiller is the only way to go. (Is this true? First thing I do is turn the wheel when I get to my boat. Is there any problems with forcing the wheel when the engine is off?)
Hopefully next week will shed some more light on the choices. Might not have room underneath for a kicker mount or might not have clearance below the waterline for the electrics. Thanks to everyone nevertheless.
MajBach
smokeonthewater
nope you can steer all you like... it will just be difficut
Shark_bait99
I have tried to turn my 25ft cuddy into a trolling machine. Here's how:
Pro-troller attachments for the stainless steel Nauticus Smart tabs. The plastic ones won't deploy to full trolling position.
- I actually have the plastic sx, which in the regular trim tab position slow the boat from 6 mph idle to 3 mph. In trolling position with the pro-troller brackets, you should be able to get those slow lakers.
-I am considering a drift sock for Amish outfitters or a 5gallon can with a few holes to slow me down to 1.5 to 2mph.
The backup motor is a 30lb thrust electric trolling motor. Use the original clamps to attach to the swim platform ladder. Pushed me and my 5200lb boat into the wind (but NO current) when my prop shaft seal failed and my leg flooded with water. Ouch. I don't deal with a lot of current, so more thrust is required in your case.
Finally I have found a good spot near the stern to mount a removable compact downrigger.
We don't have the ideal boat for fishing , but it doesn't mean it can't be done.
ondarvr
As long as you can get to the inside I don't see a problem mounting a kicker bracket, a metal fabriction shop should be able to make one rather easily. You may need to beef up that area from the inside, a piece of Starboard won't really do the job though, it's too soft and will deform easily and not spread the load.
I'm not a big fan electric backup when out in the areas you plan to be, the currents, tides and wind can become too much for an electric to overcome rather quickly, and when you push them that hard the batteries don't last very long.
kemo111
Since no one mentioned it i will. Propane boat motors are small and reliable. They are something im looking at for a small boat i have and possible tossing below deck on my boat when we go out. Speed does not matter to us just that we make it home.
JimS123
Twice in my life I saw propane tanks start to leak. The end result both times was an explosion. In one case it resulted in serious burns to an individual. In the other there were several fatalities.
My propane grill is out in my backyard, a long way from the house. I realize that the new motors are state-of-the-art, completely relaiable, cheap, wonderful and all, but the thought of propane on my boat makes my neck cringe.
Regardless, the OP still needs a motor mount for one of those, and that's what we're debating.
