I been wanting to hook up a voltmeter to my engine but from the instructions that came with the meter is is hooked up direct to the battery. Doesn't seem logical to do this as it is a constant drain, how ever little it might be. I have a 115hp mercury, inline 6, 1977. From looking at the prints of the wiring diagram it looks like the best spot would to be hook it up to the white wire and to ground so that it will be switched off when the ignition is turned off. Does this make sense? The white wire does run to the switch box and that has be a little concerned about shorting that out, to much money for one of those. If anyone has some feed back please post. Or if there is another route to take please post that.
Jimmy
Jimmy
