identify this outboard
sptjet90Reflexx
I dont have a serial number yet as I have not picked up the boat. Can anyone identify this 115hp Mercury?
I am curious as to the DC Amp output of the stator or alternator not sure which this is equipped with yet.
Its on a 1988 Tracker Party Hut 28ft
Re: identify this outboard
Looks like an 86 / 88 model.----If still using the seperate tank /automatic oil mixer you should take it out of the boat and throw it away as far as you can.
sptjet90Reflexx
Understood. I read that this motor might actually only be 90HP cause of the way they were rated? Is this true? What top speed should I see assuming I am propped right for a 28' tritoon?
Chris1956
That motor should have an unregulated stator/rectifier charging system of about 9A, at cruise. A 28 foot 'toon would need a pretty low pitch prop. Any guess I gave on the exact pitch would be a wild guess.
It is 115 HP , best not to listen to some folks about outboards and horsepower.
wired247
It is a 115 HP motor rated at the prop. Its ALMOST the same basic motor as the older crank rated 1500's with a little less compression. 9 Amp unregulated charging system. Pushing a 28 foot pontoon I wouldnt expect much more than 25 MPH if that. On a heavy pontoon boat a 15-17 pitch prop would be right at home. I'd opt for the 15.
Chris1956
Crap, trade that thoroughbred Merc in for a plough horse Johnny Fat-Fifty. You will get 25 MPH out of the Fatty, any you won't feel guilty.
Just a joke....
Big Fish Billy
Ditto...also depends on how much beer & rum you've got onboard....keep it near the bow....my buddy has about the same setup, and it goes about 26 according to the GPS...doesn't take long to get set up at the sandbar...don't forget the chainsaw engine blender, got to have that.....
sptjet90Reflexx
haha thanks guys. I should be picking her up on Friday.. We shall see what she can do!
sptjet90Reflexx
Anyone recommend steps on how to check the oil injection? I keep getting mixed reviews. Also maybe a link to how to disable it correctly?
sptjet90Reflexx
Looks like someone already removed the oil injection. It has a 13p prop on it any one know if this will work correctly on a 28' pontoon?
Chris1956
I would try the 13P prop, and adjust from there. Each 2" of pitch up will reduce max RPM by about 400RPM.
