Identifying a Trailer Hub
Texasmark
Recently acquired a 2002 model Heritage Custom Trailer. Pulling up the Heritage www today, they talk about Vault Hubs on their trailers. Wondering what is on my '02. Peculiar end on the hub, like a solid, cast, (not stamped like on most non boat types with the lip for removal) steel cap driven into a larger hub race ID, almost flush. No grease zerks and no apparent way to remove it.
Was reading on different lube methods on trailers in general and picked up something about a hub with a cap that you pack with grease and then drive it on. This may be one of those. No experience with anything like that.
Anyway, currently hubs are barely warm after running 50 miles at highway speeds, jacking and rolling the wheel is smooth as silk, rolls freely. Just want to know how and why so I can understand what kind of maintenance would be required of me.
Thanks for your time.
Texasmark
No. That's what they are using currently. Mine is almost flush with the hub casting which is part of my wonderment....how would you get them out for servicing. Thanks anyway. I sent an email to the company in hopes of finding out what's what.
Texasmark
Yes and also uses the word Buddy which makes me wonder which is the chicken and which is the egg. I used BBs back when they came out....forget when. Never heard of these before but the trailer mfgr has been building custom trailers for decades. But they solve the problems with BBs I had.
GA_Boater
The big difference may be higher pressure lube than BB's. :noidea:
Texasmark
May be due to 3 things I noticed:
Inside axle seal is built to stay in place with positive pressure.
2 orings used to ensure the piston seals
3 pressure on the pump to push the piston out...wasn't like a Zerk on a new bushing, but you had noticeable resistance when pumping....spring must be stronger.
