Fishstick1962
- Jun 21, 2006
- 114
Hey guys:
I'm working on a 2005 90ELPTO OL114324.
It was idling rough a coughing a bit so I pulled the Carbs, cleaned them with Power Tune really good, Blew out all passages and re-installed them. Adjusted carbs with a vac gauge all was really sweet. Motor purred. Motor sat for a couple days and when I started it again it ran like sh**! Started going through the carb adjustments again and found that carb #3's idle mixture screw has no affect on the idle. Pulled carb and I think the carb base seal is bad. It is an O-Ring and doesn't have much "O" left in a few places. My experience says that if the mix screw does nothing then the base gasket is bad. What do ya'll think. Any input would be greatly appreciated.
