tfbrown1270
- Sep 5, 2003
- 202
My 1994 Evinrude 20 hp was running well till I decided I should adjust the mixture screw.
I discovered the following as I progressed..
-When I turned the screw in to the stop BY HAND to see where I was starting from it went in 3 1/2 turns.
I removed it to clean it and shoot some deep creep in the hole,
-When I put it back in I retightened it by hand then backed out 3 1/2 turns (should have been where I started),....ran awful, sounded wierd and didn't smoke much. I had to back it out another 3 turns to keep it running..
-After I reseated the needle by hand I found it would go in further with the help of a screwdriver, not turning hard or anything like that just till it was seated.
Then I backed out the recommended 1 1/2 turns and it wouldn't even start..
I ended up backing out 7 turns from seated (with a screwdriver) till it was running reasonably smooth again.
Clearly I should have left well enough alone.
Anyway..since I did what I did...
-Can I hurt the motor by running it with the needle set that far out?
-Which way was right..set the needle by hand or with a screwdriver?
-What next?
Thanks for all the help...
-What next?
