if the stator was not working could it effect........
daviddustyy
if the stator (not starter) was not working would this effect the throttle or the engine from going faster than it should when at WOT under load because its fine in the tank or with muffs on but in the sea it seems really restricted like quarter throttle also the battery never seems flat? <br />if in deed i do need one how much should i be looking at from my local outboard centre as i don't want to get ripped off <br />he is charging me £20 just to test the old one is this right? as he has not even had to take it out because i have.<br /><br />mariner 50 91 ish<br /><br />any help would cheer me up at this point because im close to selling the dam boat
LubeDude
Re: if the stator was not working could it effect........
When mine went out, my 150 merc ran like cr*p. I just took it in and they charged me $385.00 to replace it.
roscoe
Checking the stator is pretty simple, if you have a test meter.<br />Simply measuring the resistance between the two leads should give you an indication. If it is in the thousands, it is shot. It should be 700 ? ohms.
daddypyke
It is your stator that is bad I had the same trouble. $175 on a 90hp merc
snappernz
mine went wouldnt rev over 3000rpm $670 nz to fix<br />on a 96 60 hp mariner
PierBridge
Originally posted by LubeDude:<br /> When mine went out, my 150 merc ran like cr*p. I just took it in and they charged me $385.00 to replace it.
What a great site just found you guys.<br /><br />The search button has brought me to this thread so it looks like my stator for my 82 115 merc should be somewhere between 350 to 650...?<br /><br />It must be pretty labor intensive I think the stator is only like 80 bucks does that sound right..?<br /><br />Thanks again great site..... :)
daviddustyy
had the stator tested all ok i have now been told it could well be the trigger £115 for part <br />could this be true?<br /><br />and also i have been told by the garage that some new plug leads for a mariner 50 91 ish 3cyl<br />will be about £35 each :( cor blimy gov<br />dose all this sound right to you ??????<br />will it fix the problem or just cost me even more
