ignition switch??
tashasdaddy
look closely at the ignition switch, where the key go in. there should be a number. a johnny/rude dealer can get you a key with the number. try and get the key out. wd 40 and tweezers. you really don't want to open the old controller as the wires are probably in bad condition. you can pick up used controllers with wiring harnesses and cables on ebay for a reasonable amount.
