DavidPR
- Aug 13, 2012
- 13
I bought a new replacement ignition switch today for my 1978 Johnson 70 HP outboard and I am having some trouble identifying the right connectors. The ignition is in the side mount control box.
The first picture is the product and the second and third shows the letters next to the connectors. On the left side you can see that one connector can either be A or S.
My old ignition switch had 6 connectors. This replacement one has 5 connectors and 1 female type that a screw goes in that is marked "M", which I'm guessing is for the 2 black ground wires that were together on the same connector on my old switch. And the other stand up connector labeled "M" is for the other single black wire. It looks like the center stand up is marked C for the purple/white wire (choke wire). I see the one for the red battery wire marked "B". But I don't know for certain about the two connectors on the left and lower left. Which is A and S?
Thanks.
Thanks.
