Moody Blue
- May 24, 2004
- 3,136
and a trap. Just uncovered the boat from its winter wrap and found this crumbled white mess all over the floor. Odd I thought, I'm sure I had thoroughly cleaned it before covering it for the winter. Soon it became apparent that the white mess on the floor was small bits of floatation foam. I then opened up the forward storage compartment and found chips and chunks of foam 6" deep filling the whole compartment. There was also little tufts of fur all over the carpeting. I am assuming it was/is a racoon that was nesting over the winter. I now need to come up with some way of replacing the foam and getting rid of the racoon.
This is a 1971 runabout where the foam was formed onto the underside of the deck in the bow about 8-10" thick. There is no foam under the floor at all. I'm thinking I might just remove what is left and then cut thick blocks of styrofoam and glue them in place. Any other suggestions would be welcomed.
