I recently purchased a 1969 Sea Sprite 15' trihull with a 1970 60hp Evinrude. When running at 2/3 to wot it lists to port about half a bubble. The boat tracks in a strait line but lists noticeably. It also seams more "surefooted" turning to port than starboard. What can be done?<br /><br />The hull is shaped like an older v-bottom, flattening out towards the rear. The two forward hull projections are not nearly as pronounced as some tri-hull designs. The interior is very spartan so I'm guessing the hull to be fairly light.<br /><br />The Evinrude 60 is equiped with a 13.25X17 OMC aluminum prop and a stingray hydrofoil. It does not have power trim. It seams to excellerate briskly and tops out at 27mph according to my 1969 speedo. I have no tack but it sounds right at wot. The antiventalation plate is slightly lower than the bottom of the boat, maybe 1/2", and the center of the hydrofoil kicks up a rooster tail. I think the hydrofoil may be causing more drag than good.<br /><br />Any advice or opinions are appreciated.
