I have a 1978 2.5L 4cyl which I put a new head gasket on. After i ran the boat it ran fine, but the next day was the problem. I ran the battery down by leaving on the key overnight and had to take it out to charge it. When I put it back in I put the cables on the wrong terminals for a few seconds and the starter began to turn the motor over by itself. After I put the battery in correctly, the boat will not fire up and seems to have a weak spark. By weak spark I mean a light orange pop that looks weak. The boat started up on a turn of a key before. What could I have burned up or messed up to cause this to happen? I have replaced the coil, rotor, cap, wires, and plugs with the same results of a weak looking spark. I had to mess something up when those battery cabals were attached the wrong way. What could it have been? any help would be appreciated. THANK YOU
