Impeller woes.....
smsscuba
When replacing the rubber impeller, what is the correct method to use to ensure the blades of the impeller are facing in the right direction?
I am sure I have the impeller on wrong.
crem1
Re: Impeller woes.....
As long as you hit the key, the direction will straighten out itself
Chris1956
In additon to what Crem said, turn the driveshaft CW (looking down the driveshaft), while seating the Impeller housing over the blades. That is the direction the motor turns.
gss036
Just look at the old one when you remove it and put the new one with the blades turned the same way. A little Vaseline or dish soap will help. As stated above, it will correct itself when running.
crem1
Ussually the biggest complaint is marrying the lower unit to the power head
crem1
If the impeller has a key receiver on both sides then you can flip it but not otherwise
