Re: inboard or outboard?
Shamrock is a good inboard choice. PennYan also made smaller tunnel drive models for shallow water running -- actually all tunnel drives are built for shallow water running, whatever the size. (Backing is a little difficult I hear, but is anyway for single engine inboards).<br /><br />If exploring shallow water in creeks, or something similar, an outboard skiff is probably the best choice. For skiing, tubing and fishing (and some cruising in relatively sheltered water), a 17 to 20 foot runabout is probably a good choice for a first boat -- particularly if you intend to trailer it. In that case, I would pick an outboard over an I/O (versatility and simplicity).<br /><br />But you have to try an inboard at some point in your boating career.... And if you hang around a marina a while, or watch the boats move out of the channels toward open water, the sound of those inboards will hook you. And if one of those boats is, say, an old Chris Craft with a pair of finely tuned 327s just idling along, you may never go back -- or at least you will need to be a two boat owner.
