Re: Inconsistant spark on bottom 2 cylinders? Need some help
Rectifier failed diode tests, it is dead.
Stator yellow to yellow NO Ohms, the charging circuit is dead.
Replace both.
Check the CDI Electronics prices, often much better than Merc and higher quality parts.
Most all CDI stators are no longer epoxy coated is that tends to trap more heat and contribute to earlier failure.
That battery didn't contribute to this failure unless its age is so great that it requires far more current to recharge. Just to be sure, take it in and have it load tested with a REAL carbon pile type variable load tester. Don't waste your time with one of those electronic meters, many of us still don't trust them.
Replace both.
