- May 29, 2003
- 19,593
Re: increasing lake level
If you have an inflow and an outflow, then you have a current. It might be a negligible current, but there is still a current ... water is "pushing" into the resevoir and water is being "pulled" out. So there are currents that are happening. Each cove that has water coming into it has a current heading out to the main body. If there is no inlet, then the current is pushing the water to the back of the cove when water levels rise and bringing water to the main channel when water levels are decreasing.
So there are multiple currents occuring in the lake at any one time.
If there are currents, then it is not too difficult to imagine the differences, albeit slight, from one end of the lake to the other. I have often wondered this at Raystown and would love to have some gps equipment that was EXTREMELY accurate (to the .00001 of an inch). One person and one end of the lake and one at the other, determining the water level at each end. I THINK you will find that the inlet side of the lake will be slightly higher than the outlet end.
I also wonder what an expert would say...
(I think you will find differences not just from one end of the lake to the other, but also from the main channel to the backs of coves - this is not accounting for the changes that wind will cause, I think we all agree on that aspect of the water level change.)
