I would still bet the transom is not angled as much as it should be. Impossible to tell from the picture.
Not that this solves an issue of improper transom angle or trim pistons not fully retracting, but why do you need more "in" trim? Seem like that drive angle should still be effective for trim, and once on place you'd likely trim it up further anyhow? Maybe I missed it earlier, but I just don't understand what the reasoning is. I would think that you would be plowing/bow steering pretty hard if you were on plane even with that trim level.
Also may be redundant, but have you tried just bleeding the system? If nothing else, it might allow you to ensure that the trim is fully retracted if the system is depressurized.
Currently, I find that the hull rides best when the drive s trimmed right in, unless the water is dead flat,then I can trim out just a little. In a rougher sea I am relying too much on the trim tabs to get the nose down to reduce pounding and improve ride. If the drive could be trimmed in just a little more then I feel I would get better rough water handling. Time onto plane would also improve, but that's not my motivating factor.
Hmm, not really an easy fix for the fellow?!
I'm now wondering whether my quest for more nose down force could be assisted by fitting one of the many cavitation plate hydrofoils, such as our locally made "Permatrim"? Since my drive does have a certain amount of "in" trim the Permatrim would also increase the amount of hydro-dynamic deflection - basically acting as a single trim tab selected to "bow down".
Unless the installation is at least 1" above the normal height, adding a 'wing' on the drive will cause more problems than it will solve.
I will be working near you in Feb/March. If I get the opportunity, would you like me to come and take a look?
Chris.....
Hi Guys:
I think I know why the rams are installed as they are in the first picture because mine are installed the same way! I purchased a set of aftermarket rams from SEI as they were cheaper than repairing the old ones. They came with the stainless connections as shown in the photograph and like the photograph can only be installed upside down on the MCM 1 drive. I don't know whether this would have any effect on the trim as mine works fine with the same method of installation.
kilowatts
