Info on 89 ski supreme for Wakeboarding
plinds
Does 0 anyone know if and what the best tower for an 89 ski supreme would be. Might be inheriting this boat from my father in law. Would also like to know if anyone knows if this 240 hp motor can handle a fat sack or fat sack seat. Any info would be greatly appreciated
rallyart
Re: Info on 89 ski supreme for Wakeboarding
You could look at Monster towers. There are several brands that will fit. Just make sure it folds well, and try to find out if it might rattle or squeek.
The 240 will be no problem. I'm sure you'll have to drop the pitch from a ski prop to handle a weighted boat. Look for a CNC machined prop. I suspect, but don't know, that you will have a 1:1 transmission. If that's the case you want a three blade prop.
plinds
Thanks, i will look into it. And do u know by any chance if the hull can withstand the added weight of a fat sack?
ThreeMileBayWaker
YOu can safely add as much weight as the yellow coast guard saftey sticker says you can... Many people go over that, but I wouldn't. My boat is 9 people or 1250 lbs. But that is a TON of ballast and will surely bog down your motor a bit.
