Info on oil pan
tom135
Hi All:
I got a quick question I hope somebody could answer.
I have a 1989 4.3L Mercruiser and would like to put a quick oil change fitting in place of the oil drain bolt. My question is, what is the size of the drain bolt that is in the oil pan. There are different sizes of kits, and I want to be sure I get the proper one.
Thanks for any help, it's much appreciated.
Cheers
Tom
Re: Info on oil pan
Ayuh,... It Should be 1/2" fine thread...
tom135
Re: Info on oil pan
Thanks for the info Bond-O, dose 1/2-20 sound right?
zbnutcase
Re: Info on oil pan
Just beware if your engine has been changed to a later vortec by chance, it will have a cast aluminum oil pan and those threads are metric. 'nutcase
tom135
Re: Info on oil pan
Thanks for the tip nutcase. I looked and it is a steel oil pan. So I think I'll be ok.
Cheers
Tom
rodbolt
Re: Info on oil pan
why not simply suck it out the dipstick tube as designed ?
cr2k
Re: Info on oil pan
Unless you change your oil like 7 times a summer those bottom drains aren't very good. All the gunk in the oil will settle there and plug or partially plug the hose and banjo fitting.
Last one I tried to use...I left it draining overnite (summer 80 deg all nite) and still sucked out over 2 qts of oil the next day via the dipstick.
If you do look at one, take a look at the hole sizes in the bolt. You will see what I mean.
tom135
Re: Info on oil pan
Thanks fo rthe suggestion. My concern withsucking out the oil from the dipstick is that I would not be able to get all the sludge from the bottom. Not sure if this is a valid concern, as I have never changed the oil in a boat engine before. I think I will stick with the regular method.
Cheers
Tom
ziggy
Re: Info on oil pan
sounds like that is the regular method...
my boat is old and sucking it out the dipstick tube is not the regular method. though i don't know what is as my drain plug is non removable w/o tilting the engine up. that said. i love my engine oil siphon. aftermarket through the dip stick tube. i use a plastic tube down that goes down the dip stick tube. it reaches the bottom of the pan. after i suck all the oil out. i know i've got all of the oil out as i can tap the bottom of the pan with the plastic tube of the oil siphon. you can hear the ting ting ting of an empty oil pan.... them oil siphons really work good. imho... oh, forgot to mention the lack of mess with using an oil siphon too. very clean way to change oil...
fishinpa
Re: Info on oil pan
QUOTE]
well you should not have any Gunk in your Oil.
If you do sounds like your pump isnt doing avery good job when you are changing oil.
fish
dpoff
Re: Info on oil pan
You might want to look at the angle of your boat if it is on a trailer and crank the trailer up or down to get the oil to drain properly.
