I posted this on "Scream and Fly" but knowing there are some "Inline" people here thought I would try here too.
Well I got my boat back Friday after they replaced a bad exhaust cover gasket that was spraying water onto #6 (Earlier post I relayed that they thought it was the covers). They also replaced the lower switch box, said it was intermittent. Took it out the next day (today) and it wasn't right from the start but got worse as time went on. What I noticed was that my voltmeter read 2 volts lower than before (was at 15.5 now at 13.5). With a hole shot it won't go above 2000 rpm without dieing. But if I run at 2000 or a little lower rpm the voltmeter heads up toward 15.5. When I get to 15.5 volts it will take off just fine. If I go to idle the voltmeter slowly heads back down to 13.5. If I take off before it gets down past 15.0 it goes ok but if it gets below that it falls on its face and will stall if i don't back off. Any clue? I guess it will go back in Monday but thought I would see what you guys thought.
