inline 6 rear motor mounts
vxtech
what is the expected life expectancy of rear motor mount bushing? i ask because steel bushing has torn from rubber again 10 hrs use across 2 yr time period, also what could cause only the port side to fail ?
Bt Doctur
Re: inline 6 rear motor mounts
Excessive flexing of the front mount may cause the motor to "torque over" more than normal.
vxtech
i do know that the front mount is aged, can i service the front mount bushing or do i replace complete front mount
Bt Doctur
i was speaking of the wood front mount.
vxtech
front mount metal,is secured to solid piece of wood (no movement) lag bolts were replaced with bolts and nuts with a stainless steel plate under wood mount acting as full length washer for bolts, however the front rubber bushing seemed soft when i replaced rear mounts but was unable to find replacement bushing for front bracket , its a very torqueing motor , i didn't think fresh rebuild would stress mounts this bad after at least replacing rear mounts only
