Installing heat exchanger
kvkon
I have a 2004 4.3 MPI/Alpha 1, raw water cooled, single point drain. I have a heat exchanger I want to install (engine only). Would anyone have a flow diagram for the current setup? Anyone done this install? Tips? Thanks!
achris
More fish than mountain goat
2004, too late. Heat exchanger needs to go on with less that 10 hours or 6 months in salt... You'll cause more problems than you'll solve by closing the cooling system now.
if you had a fresh water only motor, then you have a chance to use a HX. otherwise after 14 years, it wont help a bit
kvkon
Fresh water until this year. Has less than 10 hours total salt time and drained and flushed after each salt water dip. I'll pull the thermostat housing and see what it looks like. Thoughts? Another question, if I run it this way until the salt eats it and then build another one with HX installed what do I need to look for in a block? Will the correct casting number give me all the mounting points and connections I need?
achris
...Another question, if I run it this way until the salt eats it and then build another one with HX installed ...
That is going to take quite a few years... Saltwater engines are generally good for 20 to 30 years, as a minimum.... Or until the elbows rot (because they are not being inspected regularly :facepalm:) and take the engine out.
Chris......
kvkon
Wow, OK I'll just run it as is. I wasn't aware I could get that kind of life out of a raw water cooled engine. Thanks all!
your exhaust elbows will only last about 5 years. your manifolds may last 10. the block and heads with proper maintenance will last another 20-30 as Chris stated
however every few years you need to pull the elbows and inspect. when the elbows go, they leak water into the motor which kills the motor.
also, your impeller wont last as long in salt.
kvkon
Thanks, excellent info. I have the dry joint elbows. Any thoughts on them vs old design?
achris
Yeah. They're great! Takes away the weak point in that old design. I'm on my second pair of elbows, the first lasted 8 years...
