Re: Installing kill switch
You don't have to run wire back to the motor, it can be wired right into the ignition switch at the helm.
Generally speaking, most boat ignition switches have an always on 12v wire from the battery.  When the key is turned to the "on"/"run" position, the 12v is connected to the ignition wire, sending power back to the ignition circuit, allowing the motor to run.   The lanyard is wired into the ignition wire at or near the ignition switch in such a way as to make the ignition wire take a detour through the lanyard switch.  So when the lanyard is disconnected, the ignition is shut off.  If you put the lanyard in the dash near the ignition switch, it should be easy to make the connections.   You just have to identify which wire is the ignition circuit.
