Mano del Sol
- Jun 1, 2007
- 56
Re: Installing Smart Tabs need help
Depth.
Countersinking is deeper to accommodate a flat head screw. A chamfer is basically a de-burring operation.
Go buy an 82? countersink tool from the hardware store and it'll work fine. If your boat is aluminum then I would recommend the kind with a single cutting edge like this:
Or better yet this: commonly known as a Weldon tool.
They cut a nice smooth chamfer when properly used.
If you are chamfering fiberglass then I thing a multi-flute tool would be better since the single will probably grab and butcher the hole:
Just take it easy and chamfer it just enough to to eliminate any burrs and so you can see the flat all the way around. The flat will probably be about 1/32 of an inch wide. Don't make it too huge or you may weaken the hole. If you are scared then I would practice on something else first so you can get the feel of using it. They are not that difficult but I have butchered a few holes with a hand drill before and I know how it is.
Just my 2?
what is the difference in chamfering and a counter sink?
Guess I am being anal but I only get one shot at doing this right
Depth.
Just my 2?
