scottn83
- Aug 26, 2011
- 187
I need some tunes in the ol runabout. I purchased a Boss head unit MR1580DI a set of Infinity Reference 612m 6.5-Inch a set of Infinity Reference 6912m 6 x 9-Inch and a MB Quart Marine NAU460 240-Watt.
I have got a 6in and a 6x9 paralleled for one other 6 in and 6x9 Paralleled for the second channel and bridging 3 and 4 for a 10in sub that already had.
My real issue is when I installed the head unit I have 12v and ground run from one of my acc switches on the dash. But the head unit will not come on. I have 12v at the 12v wire and ground on the head unit connector. Do I need a chassis ground straight to the battery. If anyone has a wiring diagram that would show the connections between power the head unit and the amp it would be a great help.
one other question is the remote connection what should be hooked to the ignition switch and then a direct wire from the amp to the battery for the 12v connection
