installing the drive with new gaskets
kewlkatdady
So I'm installing my alpha 1 gen 2 drive. I have this gasket set.
On the bell there is the big black ring in the drive bellow and the water inlet gasket that has some sort of adhesive...
Can I use this as an adhesive?
If not, what do I use?
Lastly...are the little orange seals for the drive shaft? I see 3 o-ring on the shaft...I assume so, but want to ask
StevNimrod
Re: installing the drive with new gaskets
Never used amazing goop. Somebody will probably chime in to say you "can" use it, but I believe Merc says you "should" use bellows adhesive. Bellows adhesive is nice to have around anyway if you're going to be working on it yourself, but your call.
Big o-ring for water inlet.
3 smaller o-rings for shaft.
Ayuh,... Don uses bellows adhiesive for the Big o-ring, 'n the water passage o-ring...
I use a big ole gob of Grease myself,....
Ya just gota be alittle more careful it stays put that's all...
kewlkatdady
Bond-o...kinda funny you say grease....I normal lubricate o rings (auto world)...
glue'ing them sounds alien to me.
StevNimrod
I'm with Bondo on a glob of grease on the water o-ring. More fun that way anyhow.
Kewl, I think Bondo made his own special formulation of grease, but I can't locate the picture at the moment.
Ayuh,... Actually, it's created, 'n produced by my Good friend, Don....
attachment.php
Fishermark
I too use grease on the water passage o ring, but I glue the big black rubber ring in place. If you do not have bellows adhesive, you will find that 3M Weatherstip Adhesive is the same thing.
Don S
Am I loosing it ????? I know Achris and I both had a reply in this thread, now they are gone. ?????
did anyone else see my reply or the one from Achris?
EDIT: Never mind, I am loosing it.:redface: :redface: Wrong thread. Here is the one I was thinking of. :facepalm: Same subject.
http://forums.iboats.com/showthread.php?t=461649
kewlkatdady
Mine was the first one started on this subject:D:cool:
Ayuh,... I hear these sorta things happen when We get Older,.... :D :D
Don S
Could be, I don't remember....................
I even screwed up the other post.
