Instapak foam bags to replace wet foam in 16' aluminum?
kcassells
yup
kcassells
Ahhh.. sometimes its easier to just toss the chunks over the side then gather them up for disposal. I used a sawsall with a blade just short of the hull and criss crossed until I could pick up the pcs. of foam. Then a claw hammer to pull up the squares. Lots of bags. Down to the bottom another tool like a mini sawsall with a scrapper blade then back to grinder..
Lastly the clean up.
You are getting there.
KC
Waitara
Update: I did the 2-part pour-in foam. It didn't stink, but I waited until we had a nice hot day in April and I did it outside. I used sliced up pool noodle to keep the liquid from going under the gas tank or wherever else I didn't want it. Glad I went with the structurally-solid option that adhered itself to the floor. I've since replaced the transom and nearly everything else on this boat - hoping to take it out for the first time since rebuild. For anyone reading this seeking wisdom: I saved quart yogurt cups for months. Glad I did - I bought a 12 pack of mixing cups and burned through them pretty quick mixing small batches. I used drill to stir it - the $6 paint stirring attachment is worth three times that price! Also, once poured - don't mess with it. I tried to smoosh it from one place to another where it got too big - anything I moved or poked at became dense and plastic-y. would have been better off just to leave it and cut it off later. I made a long C-shaped handle and screwed a section of old band saw blade to it - worked great to slice off the foam even with the floor. (I did this with floor out - didn't want to cut access holes in aluminum floor) Supplemented the pour-in with pink foam board from hardware store. Stashed chunks behind interior panels too. Any seams or holes in the aluminum floor I caulked shut to keep water out.
Hope this helps someone.
