intake/carbs
quick007
Hi y'all.im new to this site so...nice to meecha from freezing cold Maine.
My question is,on 77-79 merc 115 -90 hp.are carbs larger to make the added hp?
Is that the only change or are the intake ports larger too.both motors run a distributor.
1980 Gt-150 major reconstruct .
Thanx:)
Re: intake/carbs
Quick, It kinds depends on the year, however, you can check out the carb part numbers and get a clue as to whether they are the same. A lot of power differences were due to port timing and power boost pistons.
quick007
Re: intake/carbs
Thanks for thereply Chris.im pretty sure only a couple of these had a distributor .
I think the 90 is a 1979 and the 115 is a 78.I've already swapped the distributor cause the 90 one went bad.
Re: intake/carbs
Distributors were phased out in mid-1980 on the IL6, I believe. Look at the transfer covers. The 115HP may have the boost port and ported piston.
Mid-70s models had other differences between the higher HP IL6 and the lower HP IL6.
gwukena
Re: intake/carbs
1979 115 went to adi
1980 90 went to adi
Once hp got rated at prop shaft in early 80's the 115 basically became a 90 and the straight six 140 a 115
Re: intake/carbs
Of course the Merc IL6 150HP motor was renamed as 140HP when the 150HPV6 was introduced in 1978. It lasted a couple of years until renamed a 115HP IL6, although Merc may have detuned it some. The 150HPIL6 motors were pretty high strung....
quick007
Re: intake/carbs
Well sound like if i can figure out the easiest route i can have the 115hp on my Gt-150
even tho it will only be a 90hp again:(
