Intake choice
Lou C
Look on the side the marine units often start with a 17
ericcarr
Would it be this tag?
Lou C
that's a Merc number, if you used a Merc rebuild kit that # should work...
look at this pic, the original Rochester carb # is circled in white....
having the original Rochester # enables you to get a better kit from Cliff's.
ericcarr
OK here’s the picture I just took
ericcarr
Also will it hurt anything if I just leave the old stove choke right where it is & convert it over to electric?
Lou C
Based on the kit I have I think you have to remove it because the bracket for the conversion fits where the spring used to be; at least it does on the small block. You have a big block so your need to go research that
Scott06
ericcarr
That might be in issue…the Philips screw retaining it is pretty stripped out…
todhunter
Canoeist
This was a pretty good thread on rebuilding a qjet:
